Best Trucks to Tow a Fifth Wheel
by | Apr 16, 2026 | RV Buyer's Guide
Picking the best truck to tow a fifth wheel takes more than comparing the biggest tow ratings on a spec sheet. While that number gets a lot of attention, it only tells part of the story. Fifth wheels place a large share of their weight directly in the bed through the hitch.  Factors like payload, pin weight capacity, suspension, and overall stability matter just as much as towing power. That is why the best truck for fifth wheel towing is usually a heavy-duty 3/4-ton or 1-ton pickup rather than a lighter full-size truck.
What Makes a Truck One of the Best Trucks to Tow a Fifth Wheel?
The best trucks to tow a fifth wheel bring a lot more to the table than just a big towing number. They need the payload to handle heavy kingpin weight without getting too close to their limits. They also need the kind of torque, transmission strength, and braking power that make towing easier on steep grades, busy highways, and long road trips. Just as important, they need a solid frame and the right axle setup to keep a large RV feeling stable and controlled mile after mile.
The details matter just as much as the truck itself. A model might advertise an impressive towing capacity, but that number often depends on a very specific setup. Things like dual rear wheels, a diesel engine, the right axle ratio, and a proper fifth-wheel towing package can make a major difference in how much a truck can actually handle. In other words, the best truck on paper is only the best choice if you buy it in the right configuration.
5th wheel RV and Truck on Road
6 best Trucks to tow a fifth wheel
1. Ford F-450 Super Duty
This group’s top pick is the Ford F-450 Super Duty. The strongest F-450 configuration can tow up to 40,000 pounds with a fifth-wheel or gooseneck setup, which makes it the most extreme heavy-duty option on this list. That kind of number is a big reason the Ford Super Duty family is often seen as the benchmark for towing capability.
The F-450 is best suited for owners pulling the largest luxury fifth wheels, toy haulers, or full-time RV setups that put serious demands on a truck. On long hauls, that extra cushion can make a big difference for mountain driving, crosswinds, and emergency maneuvers.
The downside is that the F-450 is a lot of truck for everyday use. It is bigger and heavier than most drivers actually need for daily driving, so it makes the most sense for buyers who truly want to maximize their towing capability rather than a more flexible all-around pickup.
2. Ford F-350 Super Duty
For many buyers, the Ford F-350 Super Duty is the best overall truck to tow a fifth wheel. It delivers the kind of balance that appeals to a wide range of RV owners. It is rated to tow up to 26,500 pounds and carry 7,850 pounds of payload. In a properly equipped dual-rear-wheel configuration, that number climbs up to 38,000 pounds of towing capacity and 8,000 pounds of payload when paired with the high-output 6.7-liter Power Stroke diesel.
That mix of massive towing strength and impressive payload is what makes the F-350 such a smart all-around choice for fifth-wheel towing. It gives you the capability of a top-tier heavy-duty truck, but in a more manageable package, depending on how it is set up. It also comes with Ford’s latest 2026 trailer-sway mitigation system, which uses steering input rather than relying solely on braking correction. For anyone towing a large fifth wheel over long distances, that kind of added control can make the drive feel more stable and a lot less tiring.
3. Ram 3500 HD
The Ram 3500 HD is one of the strongest options for buyers who want serious fifth-wheel towing capability without giving up inside comforts. It stands out as a top choice, with up to 37,100 pounds of max towing capacity and 7,680 pounds of max payload in the version highlighted. In a properly equipped setup with the Max Tow Package and dual rear wheels, it can tow as much as 36,610 pounds, which keeps it firmly near the top of the heavy-duty truck segment. It is also ranked second overall for towing capacity, which adds to its reputation as one of the best trucks for hauling a large fifth wheel.
The Ram 3500 pairs its heavy-duty strength with a more refined feel than many buyers expect from a work truck. It has the capability needed for large RVs, but it also features modern tech and a more comfortable cabin for long days on the road. Under the hood, the Cummins diesel delivers 1,075 pound-feet of torque, which is a real advantage when towing a heavy fifth wheel through mountain grades or on long highway climbs.
A fifth wheel rv set up for camping
4. Chevrolet Silverado 3500HD
The Chevrolet Silverado 3500HD earns its spot among the best trucks to tow a fifth wheel because it brings together big towing numbers and true heavy-duty capability. It can tow up to 36,000 pounds while offering as much as 7,442 pounds of payload. It is also recognized as one of the better 3/4-ton and 1-ton truck families for RV towing, thanks in part to its comfortable ride and strong Duramax diesel performance.
For buyers who want a truck that feels powerful and dependable without leaning too hard into the luxury side, the Silverado 3500HD hits a nice middle ground. It has the strength to handle a large fifth wheel in the right trim, but it also has a reputation for being smoother to drive than some people expect from a truck of this size. That matters when your tow vehicle is not just hauling your RV, but also carrying you through long travel days with less fatigue.
5. GMC Sierra 3500HD
The GMC Sierra 3500HD earns its place on this list because it delivers nearly the same heavy-duty towing as the Silverado 3500HD, but with a more upscale feel. It ranks fourth for towing, and when properly configured as a regular-cab Sierra 3500HD with dual rear wheels, rear-wheel drive, and a gooseneck hitch, it can tow up to 36,000 pounds. For buyers planning to tow seriously, the diesel engine is also the better fit.
This is a great option for RV owners who want strong fifth-wheel capability without giving up comfort and premium features. Since the Sierra HD is essentially a mechanical twin to the Silverado HD, the real difference comes down to styling, trim, and how refined you want the inside. If you plan to spend long stretches towing a fifth wheel across multiple states, that added comfort can make the experience a lot more enjoyable.
6. Ram 2500 HD
Not every fifth-wheel owner needs a one-ton truck, and that is where the Ram 2500 HD comes in. For lighter and mid-size fifth wheels, it stands out as one of the best 3/4-ton options in this group. It offers up to 23,000 pounds of max towing capacity and 4,010 pounds of payload. This makes it a strong choice for RV owners who need real heavy-duty capability without moving up to a 3500-series truck. It is also a top contender for RVs over 12,000 pounds.
The Ram 2500 makes the most sense for buyers towing a mid-size fifth wheel who want a balance between power and everyday livability. It still takes careful math, since payload gets tighter much faster in a 3/4-ton truck, but for the right fifth wheel, it can be an excellent fit.
3/4-ton vs. 1-ton trucks for fifth-wheel towing
This is one of the biggest choices buyers have to make when shopping for a vehicle to tow their fifth-wheel. A 3/4-ton truck like the Ram 2500 or Ford F-250 can be a solid fit for many light to mid-size fifth wheels, with both models often falling into the range of up to 16,000 pounds depending on the truck’s configuration.
That said, a 1-ton truck like the Ford F-350 or Ram 3500 is usually the better long-term choice if you want more payload margin, more stability, and a little more room to grow if you upgrade your RV later on. For example, a Ram 3500 with 7,680 pounds of payload is in a much better position to handle heavy fifth-wheel pin weight, while a 3/4-ton truck with payload in the 3,800 to 4,200 pound range can run out of room much faster. That is why so many experienced RV owners recommend buying a little more truck than you think you need.
How to Choose the Best Truck to Tow a Fifth Wheel
A smarter approach is to start with your trailer’s GVWR, then estimate what the loaded pin weight will actually be once the RV is packed and ready to travel. From there, check the truck’s payload sticker, not just the advertised tow rating. You also need to factor in passengers, hitch hardware, tools, cargo in the bed, and anything else the truck will be carrying. That full picture matters much more than a single max towing number.
It also helps to think about how you plan to use the truck day to day. If you only tow a few weekends a year and your fifth wheel is on the lighter side, a properly equipped 2500-series truck may be enough. But if you tow often, travel long distances, live in your RV full-time, moving up to a 3500-series truck or even an F-450 is the safest long-term choice. In the end, the best truck is the one that gives you enough capacity to tow with confidence instead of constantly pushing the weight limits.
Match the Right Truck to Your Fifth Wheel
If you are shopping for a fifth wheel, it helps to choose the RV and truck as a pair instead of treating them like two separate purchases. As you compare different fifth-wheel RVs for sale, keep the size and weight of the trailer in mind so you can match it with the right truck from the start. A larger fifth wheel may require a one-ton truck like the Ford F-350, Ram 3500, Silverado 3500HD, or Sierra 3500HD, while a lighter model may work with a 3/4-ton truck like the Ford F-250 or Ram 2500.
The key is to look beyond the big tow rating and make sure the truck can handle the fifth wheel’s pin weight and overall size. Starting with the right match can make towing feel safer, more stable, and a lot less stressful every time you hit the road.
Ready to find an RV for your adventures?
