chevy 454 fuel problems
We have a Trek with a 454 fuel injected engine that quits after being hot under load. It has an in tank fuel pump whitch we think is too weak to overcome a vapor lock. Has anybody cured the problem with an inline pump? If so, what pump did you use?
Guess you have already changed the fuel filter?
Several had a similar problem and it was due to a couple things, fel filter and the location of the fuel lines next to a heat source such as manifolds and exhaust pipes.
OOOOPS.
Most vapor lock
occurs before the pumps on the suction side.
If you have an in-tank fuel pump you need to replace it. If you add another pump in series with it, when the one in the tank quits completely your new pump won't help.
You also need to check your voluum and pressure before replacing the pump. This could also be an electrical problem.
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
