Page 117 of 117 FirstFirst ... 1767107115116117
Results 1,161 to 1,165 of 1165
Thread: Allison Transmission Questions
  1. #1161
    Senior Member Triple E's Avatar
    Join Date
    Feb 2009
    Location
    Deer Park, Washington
    Posts
    1,346
    Keep checking in gentlemen, our guro is traveling but will check in soon. Please provide as much details as you can. Multimedia, WELCOME!!
    1997 Triple E Empress, Freightliner Chassis,
    CAT 3126, Allison MD-3060, 6 Speed
    2011 Ford Escape Hybrid, Blue Ox tow bar, Roadmaster Base Plate.
    And I am loving it.
    RON PAUL 2012 - Legalize the Constitution
    The Grandfather of the Tea Party.
    God -> Men -> Government.
    Proud member of the Liberty Tea Party.
    “In God We Trust;” in Liberty we thrive.
  2. #1162
    Multimedia check that the keypad has power when the key is turned on, the hot lead from the on/off start switch.
    Cowboy Check the plugins on the shifter pad are not coming loose and on the trans itself. there appears to be a communication problem.
    2000 Holiday Rambler
    38\' Endeavor
    330 Cat
  3. #1163
    Quote Originally Posted by cowboy8669 View Post
    believe its the 3000 shifter butons on a dutch star . fluid levels are fine new filter . but the lights shouldnt effect that should it
    Just to have the info, I'd first run a stall test. Make sure the engine is up to power and the trans isn't slipping or having torque converter problems.
    Also, check the connector at the base of the selector. Look for loose terminals, etc.
    If the light comes on, there should be a trouble code. What's that code(s)?
  4. #1164
    Quote Originally Posted by Multimedia View Post
    Hi
    I have a MD 3060 ECM and my selector switch is blank and i have tried a different ECM and also a different selector and still no good at the moment the truck wont start and the (Check Transmission Light is on ) anyone have the same problem how do i resolve the issues.
    Greetings all from China.
    Sounds like the trans TCM or the shifter aren't getting power. Make sure the power is connected, and the TCM sees the ignition signal. It'll take a vehicle wiring diagram and some patience. Good luck.
  5. #1165
    JackG
    Hi AllisonMan, have a 05 FL M2 with 3000 TRV with Transynd. Intermittant engine flare occurs at 35mph shift (2nd to 3rd gear?). Seems to occur more so when at operating temp. It was suggested by a tech at Freightliner could be solenoid connection. What does your experience tell you with this type of problem.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
