Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Hydraulic Jack Question
  1. #21
    Tires off the ground?
    Quote Originally Posted by H2H1 View Post
    hey bandalop how are you going to drive off the jack stands if the tires are off the ground. Just asking not being a smart a**., all though most of the time I am. LOL
    I do not lift the MH high enough to get the tires off the ground, just high enough to take some of the weight off the tires and suspension.
    I have read that it is recommended that you do not lift a MH high enough to have the tires "dangling" in the air. The MH brakes are useless if the rear tires are off the ground and the front suspension is not designed to have the weight of the wheels hanging.
  2. #22
    Junior Member
    Join Date
    Apr 2012
    Location
    united kingdom
    Posts
    first the jack vertical remove the plug use the right fluid in a oil can to fill the jack up then it takes time to fill when oil is to the top install plug and test it may take time or two to remove air in the end should have a working jack good luck
    http://www.hts-direct.co.uk/
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
